跳转到主内容
鞋子修理和保养指南,让您的鞋子保持完好状态。
How do I get rid of the stickyness on the sole of safety shoes
I've had safety shoes in a box for years, when i looked at them the soles were stuck to the side of the box and had black goo lines on the box. Now the soles are all sticky. I've never used the shoes and thought someone could and wanted to donate them but i don't know how to get them un-sticky, i hate to throw them out!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
The soles were probably made with some type of polyurethane. When stored for long times, especially with higher humidity present, the PU can undergo hydrolysis which will make them sticky and gooey. There is not much that can be done to fix...as the damage is done in the actual makeup of the sole. You could attempt to make them usable by dusting them with corn starch or talcum powder and seeing if it makes them acceptable.
这个答案有帮助吗?
得分 1
添加一条评论
I hear baking soda with water may remove some stickiness.
这个答案有帮助吗?
得分 0
添加一条评论
You cannot 'un-sticky' them. It is due to a chemical reaction called 'hydrolysis'. The polyurethane sole absorbs water when not worn for long time periods and disintegrates. The only thing you can do is replace the soles, discard the shoes, or contact the manufacturer. I had a pair of Blundstone boots that developed this problem. The company sent me a new pair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gkbova 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 40
过去 30 天: 207
总计 21,051
