跳转到主内容
Lenovo Essential G560. This laptop has a 15.6" screen, along with a full keyboard with number pad.
20 个问题 查看全部
Laptop Fan not rotating?
I faced this problem previously and lost my Sony VAIO Laptop the same issue is with my Lenovo.
Issue started when i found that my laptop is producing lot of heat when designing and suddenly tuned off. So i opened the back cover , switched it back on and found fan's not rotating.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @narengs7 ,
Here is a link to the service manual for your laptop.
Scroll to p.41 to view the necessary pre-requisite steps and then the procedure to remove the fan.
If the fan is faulty (use an Ohmmeter to test it out of circuit), scroll to p.74, item #10 to find the part number for the fan, (31042378). Search online using the part number only in the search box of your browser to find suppliers of the part.
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
添加一条评论
I have had a few laptop fans die on me before. Often it is due to dust that either blocks connections. The first thing I would try is removing the fan and giving it a good clean, checking connectors etc. You'll be surprised how many of them spring back to life after a simple clean...
Let me know how you get on :)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Naren 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 147
