跳转到主内容
加入维修社区 - 创建账户
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
Help separating screen from frame
Hi, I'm strugging with removing the display as described in step 30 of this guide:
Galaxy S6 (Verizon) Charging Daughter Board
I've destroyed two displays trying to slip the guitar pick between the frame and the display. Each time I end up sliding the pick underneath the black backing of the LCD exposing the silver material inside the LCD. In the guide it shows the blue pick sliding from the outside of the frame and then being visible when it reaches the inside part of the frame. Whenever I do it, the pick slides under the frame and is not visible when it reaches the inside portion of the frame. I am using heat to soften the adhesive.
Please help!
See attached image.
Replace a broken or damaged charging daughter board for your Verizon Samsung Galaxy S6 smartphone with this part. This assembly includes the USB port, headphone jack, menu button touch sensors, and primary microphone.图片
产品
$19.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Are you doing charging port replacements on S6?
I strongly advise against removing the screen to do charging ports on these as damaging the LCD is almost guaranteed.
The more ideal way to do it is to shield the components with thermal tape / kapton tape surrounding the charging port, and replace the charging port itself via soldering / micro-soldering. You will need to lift up the charging daughter board a bit so that it's away from the phone's mid-frame to distance it away from the screen.
I use a hot-air rework station to remove the charging port from the daughterboard to replace it. There should be some videos on YouTube on how to do this.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
travwilliams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 108
