跳转到主内容
Hewlett-Packard于1993年开始制造个人笔记本电脑。
3332 个问题 查看全部
Laptop does not start up without it being plugged in?
I got a HP 15 bs007ne last month and I have noticed that it never boots up if its not plugged in and charging. As soon as i plug it in to charge, it'll start up. This always happens no matter on what percentage it is. Once its on, I can take if off charging and it will work normally. I am so annoyed. I have to carry a charger to college and its definitely a hassle. Please help x
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @khanyehasprobs ,
If it's new take it back to where it was purchased or follow the instructions in the manufacturer's warranty statement (usually found in the User guide) as to what to do to make a claim for a manufacturer's warranty repair or replacement.
这个答案有帮助吗?
得分 3
2条评论:
Is a faulty battery included in the warrany? its been a month since I bought it
完成的
Hi,
It should be.
Check the warranty statement as to what is covered by the warranty and for how long.
They say in this link "1 year limited parts, labour, and carry-in service;".
Usually "limited' means that if you drop it or get it wet it is not covered.
It may be that the warranty is different for your location (depends on the rules of the country as to what the maker can get away with), that is why you should check the warranty statement that came with your laptop, as it will apply to your situation (unless you bought it in another country and then moved)
完成的
添加一条评论
If you just bought it take it back. Odds are high that you've got a faulty power lead or bad battery. Return it and get a new one. If the store wont exchange it you're going to have to go through HP's rma process. Good luck hope I helped.
这个答案有帮助吗?
得分 2
1条评论:
Thank you! its been a month since i bought it. does the warranty support faulty batteries?
完成的
添加一条评论
添加你的答案
That1pakigirl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 75
