跳转到主内容
The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
106 个问题 查看全部
Displays only black and white when turned on.
I turned on my SNES yesterday after a long period of it not being used and I found it only displays in black and white. Ive tried different cables, RF and AVI output, different games, cleaning the games, and trying to clean the contacts in the SNES. Nothing has helped. I read the post that was already here from a while back and it looks like I already attempted what that person recommended. Does anyone know what would cause my SNES to only output in black and white on a color television? Thanks for the help. Greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
It sounds to me like there's problem with a pin in the display connector port on the SNES itself. If you've had it in storage, the copper connector may have oxidized, which will put a green-ish coating on it (like the Statue of Liberty). This will disrupt connectivity between the connector and the cable. This doesn't happen often under normal conditions, as the contacts are treated to resist oxidation, but long-term storage in a non-climate-controlled location can still cause such issues.
If this is the case, the contact may be cleanable, but you'll have to be careful not to damage it. There isn't a suitable guide for this part of the system yet and my own SNES is still in storage.
It's also possible the connector port was damaged. I find this less likely, but you should be able to tell by looking at it.
Take a closer look and let me know what you find.
这个答案有帮助吗?
得分 1
2条评论:
Where should I be looking to find this?
完成的
On the back of the unit. It's the port where you plug in the AVI and RF adapters.
完成的
添加一条评论
添加你的答案
instructorarmijo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,024
