跳转到主内容
Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1017 个问题 查看全部
问题已关闭
Fans force air when turning on PBG4
Watching the Audi Channel one night the PB screen went black (that was before it stuttering on the internet connection).
When turning back on, the fans just keep blowing air and there is no display. Screen is black. No beeps.
This is 15" PBG4 - had for a bout 4yrs. Could the screen inverter have gone or is this a logic board issue.
Help appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Check the RAM of the computer try re-seating it, and see if that works. If not, you may have a much more serious problem, you may want to look into putting a shim on the CPU, and GPU, if that solves the problem, tell me, and i'll go into more detail on a permenant repair procedure
这个答案有帮助吗?
得分 1
2条评论:
Not sure I understand what you mean by "shim" - can you explain?
完成的
A shim is a non-conducting spacer between the case and the chip to force it into contact with the logic board.
完成的
添加一条评论
It's not the inverter, if that failed it would still boot normally, just with a black screen. As it is ramping the fans up that is the logic board entering CPU protection as it isn't booting, but as the screen is staying black, would say it is due to a failure on the logic board.
这个答案有帮助吗?
得分 0
1条评论:
I'm guessing it's the logic board, but want to try some things first. I do get an intermittent chime from the PB, but then it goes silent and just blows out air from the fans
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 954
