跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Home button flex replaced, touch ID not working
Hi all,
I replaced my home button (long) flex cable and now my touch ID is not working anymore. The home button, the click, is working fine. What could be the problem? The home button is still the original one.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Check both the long home button flex and the short flex on the button itself. Something is broken in that line. It could be a tiny tear in one of the corners or it could be the connectors with a damaged pin. You may need to use magnification as it doesn't take much to cause problems.
If the long flex is damaged, you can replace it. If the Home Button has a damaged flex, it "may" be repairable but generally it is not.
这个答案有帮助吗?
得分 1
4条评论:
So a 'China' long flex should also let the touch ID work with an original home button?
完成的
They all come from China :>)
完成的
Okay, thank you. But can a long flex cable let the home button touch id work?
完成的
Yes it can. The only other causes of touch ID not working are if there is a small enough tear in the home button to only affect touch id, components knocked off of the logic board during disconnection, or a defective extension flex (long flex that runs underneath the LCD shield plate.
完成的
添加一条评论
添加你的答案
Uas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 85
