跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Front Camera Not working
Replaced my battery on my iphone 6s plus and the camera 's didnt work so i took the phone back apart and re seated the ribbons. The back camera worked after that but the front facing did not. I then replaced the front face camera with a replacement out of another iphone 6s plus and the front camera still continues to be black. Any help is appreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
First question, did you disconnect the battery prior to removing the screen? While normally this would mainly affect the backlight circuit, it is still possible that it could cause other issues.
Now, if you can install the cameras in another, known-working phone, then you can determine if the cameras are good or not. The other thing to consider is that both cameras had their flex cables damaged rom the handling. The flex cables are very delicate and can easily tear. You will need to closely inspect the flex cables. The final thing to check is the condition of the FCAM connector on the logic board. It is possible that it was damaged; that could explain why multiple cameras have failed.
这个答案有帮助吗?
得分 1
1条评论:
Battery was disconnected
I haven't verified the camera yet but it can from a working screen.
完成的
添加一条评论
添加你的答案
nick perry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 6,549
