ink is smearing on labels
I am using the zp 505 printer for labels. The labels keep coming out with the ink smeared. I have cleaned it multiple times. What could be causing the smearing of the ink on the labels ?
The printer doesn't use ink, the paper that goes through it reacts to the temperature of the print head, a bit like a till receipt.
You might need to clean the print head, or it could be a faulty print head
这个答案有帮助吗?
I had the same issue. I used a alcohol wipe clean the print head. I let it dry before use and it worked find without any smearing issues.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 1,321
