跳转到主内容
修理您汽车上的喇叭 音响 CD唱机 插座
247 个问题 查看全部
DIY headunit harness fabrication
'Aftermarket Reverse Harness RCA Trouble
Im installing a double din Chinavasion "Stargate" touchscreen headunit, complete with GPS, DVD, and the other fancy stuff. A bit dated, but im po'.....not "poor"..."po". The schematic on the top of the unit shows the pinout, and that should make this a quick job, but for the RCA outs that will feed my amplifier.
It shows 2 sets of RCA's...
Set ONE: Is fed from 3 pins.....
Set TWO: Is fed from 2 pins...
How in F-......?
Thanks in advance, and ill do my best to answer any questions i can...which is why ill never work for Chinavasion. They refuse to provide an explaination, photo of an original, or to sell me a new one
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Set TWO might be a mono subwoofer output which would only need 2 pins. If set TWO is a stereo output, it might use the same signal ground as set ONE. So the 2 pins in set TWO are the positive connections, and set ONE and set TWO share a common (negative) signal ground.
This is just a guess, so you’ll need to check and make sure. Assuming these are all truly low-level preamp outputs, you should be able to test these out relatively easily with little risk of damage. Try running the pins from the preamp output of the radio to the positive (center pin) input of your amp. Then connect the negative (outer ring) input of the amp to ground. This might not have good sound quality, but it will at least help you troubleshoot which radio pin goes to what channel. Just be sure to not connect any of the radio pins to ground. If there’s a preamp pin that’s labeled negative or “ground” on the radio, then it’s probably a common negative connection for all the preamp outputs. That one pin can be used for all your preamp channels and - again - don’t connect any of the radio’s preamp pins to ground ( :>) ).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John b. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 93
