跳转到主内容
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46 个问题 查看全部
IPad 5th gen battery issue
Ok so I had a guy bring me an iPad 5th Generation in to my shop with a cracked Digitizer to get repaired. While testing it I noticed the battery shows 1%, so I plug it in to charger and once the charger recognizes it shoots to 100% and will stay on for about 10 seconds then shuts off and turns back on at one percent, within a few seconds shoots back up to 100% and just keeps cycling through.
It was doing this prior to working on it, I went ahead and replaced the Digitizer but cannot figures out what could be causing the issue.
Do you think it’s possibly a bad battery? Software? It has an update available but shuts off before it can update, thought about trying through iTunes but don’t want to do that and then the iPad get stuck in recovery if it shuts down in the middle of an update
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
UPDATE: upon further inspection I can confirm it’s most likely a bad battery. I spoke with the customer and they said it stays plugged into a Square register dock 24/7 which leads me to believe the battery is shot
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
chad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 955
