跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
replaced screen and dispay wont work
I am replacing my front glass and back glass and before I attached either screen, I hooked up the display to see if it worked and the phone will turn on but the display wont work? ive hooked up everything on the motherboard besides the fingerprint sensor. what could I have done please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First put back the original screen to see if you see anything.
If the original screen is showing you data then your replacement screen Is malfunctioning.
这个答案有帮助吗?
得分 1
3条评论:
its the same old screen, I just put new glass in and the display has a little tear in it??? that might be it
完成的
and the layer between the glass and the copper piece was stuck to the old glass and messed up so I just ordered a new copper piece and screen
完成的
if the display has a tear in it. Look no furhter.
you need to replace it.
完成的
添加一条评论
添加你的答案
Braden Farnworth 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 61
