How do I replace the coil and the wires leading to the coil?
Hello, one my upper heating coil, one of the wires leading from the power to the coil has rusted and fallen away from the coil, so it doesn't heat. Is there a replacement wire assembly for this, and how do I open the griddler to detach and then reattach the new wiring to the griddler so that it will heat up again?
Hi Karen,
do you have the solution for that?
I have the same problem.
由 Henrique Ferreira 完成的
