跳转到主内容
Why is my Zune not working
Microsoft Zune says contact support. I charged it up but it does not do anything. Right now on the screen it says contact support then they have the number five on it. Also a picture with an x on it. What can I do to get it to play music, games and other things that it used to do? Does it need to be updated? I had it for quite a while. A guy went to put music on it for me which I already had music and he was going to put more music on it. However when I went to play his music that he put on it. It just stopped working altogether. Can you help me. I know that is out of date but I like to still listen to the music that I have on it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
7个答案
最有帮助的答案
If resetting it doesn't work, you should reinstall the software:
http://support.microsoft.com/kb/926993
Software available at: http://www.zune.net/en-us/products/softw...
You may lose music or other data purchased/added since your last sync.
这个答案有帮助吗?
得分 6
3条评论:
Is the software on the website or the cd that
Comes with it?
完成的
I added the link to the software above.
完成的
ERROR CODE 5——Yes, It can be a HD ribbon ZIF cable loose , BUT 99% of the time the Hard Drive has gone bad. No Fix other than replacement. I have many ZUNE 120Gb players & One at a time the hard drives went bad. No reasons—not dropped. I found the best repair is sending them to RAPID REPAIR. For $20.00 they will diagnose & give you an estimate. The smartest repair is having the Hard Drive (which is mechanical & will go out again) Replaced with a SSD digital drive. No moving parts, Solid state Memory, WITH a plus that they can replace the 120Gb drive with a 128Gb drive with extra memory. I’ve now have all 4 of mine done, Some with a new battery at Approx. $ 200. each or less. Just don’t throw that old ZUNE away ! Even broken, It’s worth big money on EBAY to guys & girls looking for parts that are NLA to fix their’s. Hope this advice works for all that live with ZUNE everyday like me. The best player ever on the market.
完成的
添加一条评论
此回答最初是针对另一个问题
I fix these for a living, the number Five Error is usually the hard drive, sometimes the hard drive cable.
这个答案有帮助吗?
得分 2
添加一条评论
此回答最初是针对另一个问题
i have a contact support 5 and there is a chip getting really hot on the motherboard.(looking from the back its on the lower right side, behind the back button on the back side of the board) still say 5 is the hdd or hdd cable?
这个答案有帮助吗?
得分 1
添加一条评论
此回答最初是针对另一个问题
ERROR CODE 5——Yes, It can be a HD ribbon ZIF cable loose , BUT 99% of the time the Hard Drive has gone bad. No Fix other than replacement. I have many ZUNE 120Gb players & One at a time the hard drives went bad. No reasons—not dropped. I found the best repair is sending them to RAPID REPAIR. For $20.00 they will diagnose & give you an estimate. The smartest repair is having the Hard Drive (which is mechanical & will go out again) Replaced with a SSD digital drive. No moving parts, Solid state Memory, WITH a plus that they can replace the 120Gb drive with a 128Gb drive with extra memory. I’ve now have all 4 of mine done, Some with a new battery at Approx. $ 200. each or less. Just don’t throw that old ZUNE away ! Even broken, It’s worth big money on EBAY to guys & girls looking for parts that are NLA to fix their’s. Hope this advice works for all that live with ZUNE everyday like me. The best player ever on the market & A SHAME that MS ever ever stopped producing. But then again MS has never done too much right other than make the best music player on the market.
这个答案有帮助吗?
得分 1
1条评论:
Hi Robert. I recently sent a few email messages to Rapid Repair (8/2023) but have not heard back. They don't have a phone number listed on their website. Do you happen to know who else can fix the number 5 error?
完成的
添加一条评论
此回答最初是针对另一个问题
I have visited you blog and feel good to read comments about to fixing the zune error 5 and other but now i am focused about to fixing zune error 5 someone recommend me to visit this error site and feel the difference of services and i follow that person and really i have get a lot of benefits from this its solve almost every problem related to this error, I want to recommend you to visit this http://ezinearticles.com/?Fix-Zune-Error... and you also feel the difference between this and others sites.
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
After replacing my zune LCD screen I got this message. I took the zune apart again and found that I did not properly replace the mother board ribbon. After properly replacing the ribbon, the zune worked fine. Hope this works.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I tried nearly everything to no avail.. just for the heck of it, I band my zune on my desk a few times and *poof* it started up just fine... yup, I pulled a Fonzie.
Can't make the problem worse!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 305
