跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
Can I use 2011 iMac LCD assembly in 2012 iMac?
Hi
The ribbon connectors that connect the T-CON board to the LCD have been ripped off. There's no damage or tears to them but as they are glued and not plugged in I cannot get them back on.
I'm not sure if it is possible to re-attach or reglue the ribbons back on?
I also thought could I plug the 2011 screen into the 2012 iMac? Both share the same output resolution at 2K.
Has any one attempted this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What I mean is
Could I plug the lcd in and would it display anything or just a black screen?
I'm not looking to put it in place just see if it works.
完成的
This is not the magnetic vs glue answer I'm after but whether or not I could actually plug the 2011 LCD into the 2012 iMac.
完成的
添加一条评论
1个答案
最有帮助的答案
Sorry no. The 2011 systems are the last magnetic of the attached display assembly whereas the 2012 model is the first glued down display assembly. They are not interchangeable!
这个答案有帮助吗?
得分 1
2条评论:
Could I plug the 2011 LCD into the iMac just to see if it works though or if it would just show a black display?
完成的
Whats the point?
If you want to just see if the system is working just plug in an external monitor via the Thunderbolt port (DisplayPort to display cable).
完成的
添加一条评论
添加你的答案
itshield 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 291
