跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Screen Not Working After Replacement
Hello all,
I just replaced a screen on an iPhone 6s, and after I put the screen on, it won't light up showing me it's on. I can hear the little reminder noise, so I know that the phone is on. I have put the old screen back on, and the screen still won't turn on. I have tried disconnecting the battery and reconnecting it, but it still hasn't solved the problem.
Does anyone know what's up with this phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
If the screen got replaced while the battery was left plugged in the backlight circuit is probably blown which can only be fixed by microsoldering.
Some repair shops do board-level repairs / microsoldering which you may be able to find locally in your area.
What usually happens is when you disconnect or connect the screen while the battery is still plugged in you may see a puff of smoke coming from the screen connectors meaning the backlight filter blew up.
这个答案有帮助吗?
得分 1
添加一条评论
Could be that you got a defective screen, it's about 1 in 10 screens that I replace are non-functional. Also there is the possibility that the backlight blew.
这个答案有帮助吗?
得分 0
添加一条评论
99% your backlight filter is blown!
http://mendonipadrehab.com/entries/gener...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Benjamin Gabriel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 854
