Air or heat not blowing through vents
When I turn on the knob for air/heat nothing blows through vents. What could be the problem and how much could it cost to repair it? Thanks
First off get your car scanned, if you live in the States. Some auto places do it for free.
Check your fuses, and relays. On the fuse box it should tell you what fuse is what. Also the hand book should tell you if you have it.
If fuses and relays are good. It could be a faulty switch.
这个答案有帮助吗?
过去的24小时: 2
过去的7天: 2
过去的30天: 3
总计 183
