跳转到主内容
One of Sony's 13.3" models in the 13A multi-flip laptop line.
3 个问题 查看全部
Maintain power to Laptop when changing battery
I have a Sony VAIO SVF13N17PAB, and just received a replacement battery [VGP-BPS41] from the Sony preferred parts supplier. Do I need to maintain power to the laptop when replacing the battery? Also will I lose data/reset to factory settings when the battery is removed? Thanks Scott
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Do not change the battery while it is connected to power. Turn off your computer, then take out the battery and finally plug in your new one. No data is stored in the battery so don't worry about reverting to factory settings.
You should always power off your device when you replace a part.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Scott Evans 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 239
