跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Is this a problem with the DC connector?
I have a Macbook Pro 15-inch retina with No Power & and no green light on the charger.
The voltage from connectors 1 & 2 oscillates between 0.18V and 0.42V
The voltage from 3,4,5 & 6 is 0.
I tried to plug a known good DC board so the problem doesn't come from the DC board.
Since the voltages are bad for all pins, does that mean the problem comes from the DC connector itself?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I'm a bit confused, the other DC In-board was also failing?
I would look at the MagSafe charger and its connector. Here's a good reference: Apple Portables: Troubleshooting MagSafe adapters. Do make sure you have the correct charger as well.
You may also have a bad DC In-board. You only want to test the four outer pins the middle pin is the one wire comm between the adapter the SMC. It is sensitive to ESD and high current so you don't want to short it! Here's a bit more: Teardown and exploration of Apple's Magsafe connector
这个答案有帮助吗?
得分 1
1条评论:
Hi again, thanks for your response. I just changed the DC board and now there is normal voltage on the pins of the DC connector, but no green light, no power and no charging. Seems like I need to troubleshoot the SMC, Adapter Sense etc
完成的
添加一条评论
添加你的答案
Alex222 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 177
