跳转到主内容
Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
56 个问题 查看全部
I can not hear anyone on the phone unless its in speaker phone mode.
https://drive.google.com/file/d/1bEY6zO3...
I replaced my cracked screen on my Lg g6 and since the part that is circled in blue ink in the picture no longer works. It charges fine, Google play music app works perfect, and I can hear notifications. I am currently using another phone so not sure if can hear the ring tone. The only way I can hear someone or they hear me is if I use a headset that you plug into the audio jack or using the speaker phone. I also tried replacing the Usb C Port flex cable but that did not change anything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Several things can go wrong here. 1 make sure there is nothing covering the speaker hole on the outside or inside of the phone. 2 make sure the speaker its self is lined up with the hole on the screen. 3 make sure speaker is connected correctly. 4 Clean all the connections for the speaker. If all else fails yo may have to purchase a new speaker, Could have been damaged when changing the screen.
这个答案有帮助吗?
得分 0
2条评论:
Thanks. Are you saying the pic that I have circled in blue is the speaker or earpiece?
完成的
Yes the is the ear piece speaker.
完成的
添加一条评论
添加你的答案
tawanas82 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 84
