跳转到主内容
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203 个问题 查看全部
Turning on and off
Samsung smart tv turns off and back on several times while watching a DVD
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hi @cgrubbs1 ,
Just trying to narrow down the problem.
Does it do this when watching TV channels?
When you say turns off / on do you mean that the TV powers down and then back up again or that you just lose the sound and picture but the TV power light stays on?
If this is what happens are you using the DVD or TV remote control to control the DVD at all during viewing, e.g. pause or shift or volume etc?
Does it only occur with the same DVD disc or on any?
What input is the DVD player connected to HDMI or AV?
完成的
添加一条评论
1个答案
I had the same problem, after a couple days of this I decided to remove all the batteries in all my remotes, it turned out to be my amazon fire stick remote. Once I removed the batteries everything was fine
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Craig P Grubbs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 294
