跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Is the electrostatic pad needed with an SSD?
When pulling the stock hard drive and replacing it with an SSD in a 2011 27" iMac, is it necessary to transfer the electrostatic pad to the SSD? I just finished my upgrade and looked down to see the silver electrostatic pad still on the old drive. Rats. I am hoping that this was needed because of possible static build up from an old-style spinning drive and isn't required with an SSD. Does anyone have any wisdom to share? I can redo the job if I have to, but I'd rather not.
Thanks,
Brian
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Terrific, thanks!
完成的
添加一条评论
1个答案
已选择的解决方案
Your fine ;-}
Even if you put the foam pad on it wouldn't help as the distance is greater height wise.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Brian Irwin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 120
