跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Help with MacBook Pro temperature sensors
I have a 2015 MBP 13" Retina (A1502) which has a strange kernel_task issue and shows errors in Diagnostics ------ PPN001( i don't know what this code means) , PFM006(SMC issue), PPF003(Fan issue).
I want to be able to try cleaning out the insides, especially the temp sensors. Can someone help me regarding their locations?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I don't think general cleaning will address these errors.
Diagnostics finds electrical faults not general temp issues. You likely need to take the logic board out and do a deep inspection looking for corrosion damage and/or damaged components.
Can you fill us in on what happened with your system. Did you have a spill or get it wet at some point?
这个答案有帮助吗?
得分 1
添加一条评论
Check board for liquid damage may have a sensor issue. Also inspect trackpad flex and trackpad for any corrosion on the connection points.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chuck lozano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 762
