跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2693 个问题 查看全部
Phone wont turn on
I change display ( boken touch ) and used phone few days . After I take picture with camera the display turned white and swithed off phone ( battery was at 60% ) . Now it can not turn on . I tried with old display , but problem is not solved . Any suggestions ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Could be in DFU mode. Is it recognised in iTunes?
这个答案有帮助吗?
得分 0
2条评论:
How can i tried . Any link ?
完成的
Connect it to a computer that has iTunes installed
完成的
添加一条评论
I had the same issue because of my connections of the lcd was not right. So Check that the cables fit properly.
这个答案有帮助吗?
得分 0
1条评论:
I tried with old display that has broken touch , but the problem is same .
完成的
添加一条评论
Did you unplugg the battery every time you replaced the screen?
If not, I would check the lightning/image fuse
这个答案有帮助吗?
得分 0
2条评论:
Yes , my first thing is unplugg battery
完成的
Test an hard reset - home button and power button the same time up to a minute and release if you see the Apple logo, if that dosent work then test unplug the battery and put in the charger and see if it goes to the Apple logo. If it does you got a bad battery
完成的
添加一条评论
添加你的答案
Damjan Jakobcic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 77
