跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Both iPhone 6 cameras and flash are not working
I recently bought an iPhone 6. The phone works good overall but has one issue. Both of the cameras are out. I have replaced both cameras twice and still no result. The flash is also out too. I replaced that flex cable with no result. I am convinced this is some sort of board issue. But I cannot determine it. I’m pretty sure there is a short somewhere but I don’t know where. I hate when parts of the board fail because they almost always require soldering. Please help. I have some experience in soldering and this was a cheap phone so it’s no big deal.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Both cameras are powered by the same voltage rail; this is provided by U2301. there are some other voltage rails at play also but if they were bad, most of your phone wouldn't work either. The Flash however is on a totally different circuit (U1602) but it does communicate with the RCAM so it's possible that a "dead" RCAM causes the flash to shutdown.
Were all three defective when you opened it up the first time? If so, did you noticed if the water indicators were red? Also, was this phone repaired or dropped shortly before this occurred?
For the two cameras, you clearly have a logic board issue IMO. As for the flash, it could be a damaged flex so you will want to inspect that for tears or damage. If the flex is fine, then it's being shut down due to the dead RCAM.
None of this is suitable for a DIY repair, you should have it looked at by an experienced micro-solderer.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Adrian Ledesma 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 58
