跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Stuck in headphone mode after lightning port replacement
A customer had snapped of their headphones in the audio jack on their iPhone 6. I replaced the whole lightning connector and headphone jack but it is still stuck in headphone mode. Headphones work whilst plugged in but it will not switch back to normal mode. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
you likely have a short in your new component. disconnect the charge flex from the motherboard, and see if it is still in headphone mode.
1) if it IS IN HEADPHONE MODE, then you likely have a board short from mishandling.
2) If it ISNT IN HEADPHONE MODE, then you likely have a flex issue, and you will need to re-replace the flex.
这个答案有帮助吗?
得分 1
3条评论:
Hi,Thanks for this info. I have a similar problem and indeed the phone remains in headphone mode when the flex is disconnected. Is this then a problem with the connector on the board, you think? Any suggestions on what to do then?
Many thanks!
完成的
Is there a fix for when the iPhone stays in headphone mode even when the flex cable is disconnected?
完成的
添加一条评论
is it still stuck in headphone mode when no charge port is connected?
这个答案有帮助吗?
得分 0
2条评论:
Yes it is. The headphones work, even connected it to Bluetooth headphones but still stuck in headphone mode
完成的
When I say charge port connected I meant the ribbon cable from the logic board.
完成的
添加一条评论
添加你的答案
Andy Hilder 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 967
