跳转到主内容
A 10.1" touchscreen tablet released in 2014 by RCA Corporation.
45 个问题 查看全部
Charging circuit output to battery
With the battery removed and the charger connected, is there any reason why the terminal posts where the battery would be attached should show 0.0 voltage? My logic suggests there should be some sort of charging voltage??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @jeppes ,
This is only supposition on my part but perhaps the battery management system in the tablet needs to detect that there is a battery present (perhaps by detecting a current flow out of the battery and into the load) or detecting that there is a preset minimum battery voltage level before it turns on the charging voltage.
Here is a link that may be of some interest.
这个答案有帮助吗?
得分 3
4条评论:
The battery when reattached has a native voltage of 3.42 where it should be 3.7 . When the charger is attached or another external battery, the voltage remains the same. I realize the native battery is bad, but I would expect that the voltage would flux a little when external power is supplied. Just trying to verify its the battery that is bad and not just run down due to bad charger or circuit
完成的
Hi @jeppes ,
What is the o/c (unattached) voltage of the battery?
When it is attached it has a load on it which may drop the terminal voltage.
I agree that the charge voltage should be in the region of 3.7 V -4.2V depending on state of charge of the battery
I assume that you have measured the voltage output from the charger?
完成的
3.42 unattached. Zero voltage from the battery attachment point (charger) with the battery removed.
完成的
Hi @jeppes ,
Assuming that the battery cut off voltage is approx 3.0V then 3.42 represents approx 40% discharged or 60% charged (if my maths is correct).
As your battery (looking at the ifixit battery removal guide) has only 2 wires then the BMS must be relying on the battery voltage to know when to start and stop charging, rather than also having a 3rd sense wire (like some) that also incorporates usually batt temp into the charge parameters.
Does the tablet give any indication regarding the state of charge of the battery, with and without the charger connected?
If you have checked that the wall charger's unattached output is 5V then perhaps you may have to try replacing the battery first .
完成的
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 144
