跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 No service/searching
Hi. Just want to ask if NO SERVICE and SEARCHING on the iPhone 6 are the same fault?
I have one that has no service. I did the jumper solution and changed the power chip for it but it still has no service.
I’ve done the jumper solution for phones that were stuck on searching and had no problem with them.
Have done a checkmend and the phone is clean.
Would be grateful for any help on this
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Go to your phone’s dialing keypad and dial *#06#. Do you see the IMEI displayed?
If the IMEI is not displayed, the Baseband IC has to be reballed and two small copper traces (U1/V1) have to be rebuilt and solidified. This is commonly referred to as the “long jumper” solution. It is preferable to the short jumper solution which may fail because of damaged inner traces. You can check out this Service is "Searching" indefinitely (by @teetopp) as it summarizes the issue really well.
There is a long jumper solution being tried out by Chris Long (and others). Chris posted several videos and you can start with this one.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the reply
The phone has its imei and modem firmware Number.
Have already done the long jumper solution.
Did it 3 times but phone is still on no network.
The phone doesn’t get stuck on searching. Just no network.
Would there be any other chip that might be faulty?
完成的
Did you read through the linked answer from Michael? He goes on to suggest other repairs if you can read the IMEI.
完成的
添加一条评论
Hello. See this video for fix Searching/No Service iPhone 6 on youtube : https://youtu.be/6rx_TOfgHqg
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
trevor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 367
