跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
2010 15" MacBook Pro logic board problem
My Mid 2010 15” MacBook Pro 2.4 GHz logic board is not working because of the NVIDIA GPU problem. I tested and confirmed that the graphics card gone bad and there are plenty of reviews online that tells about this problem.
I need help from the experts here to decide whether I can buy a 2011 logic board or at least replace this one with better one from the same year (i7 2.66 GHz from 2010).
Please let me know, which logic board is required to replace that can make my mac run again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
What do you mean by GPU failed? If it's kernel panicking, this is a fixable issue 99% of the time and is NOT the GPU. Also, if it is the GPU, do NOT replace with a 2011 or your life will be even more miserable lmao if all else fails and you want a unibody, buy a 2012 15" the only good one they ever made.
这个答案有帮助吗?
得分 1
2条评论:
I am trying to replace the capacitor and fix it
完成的
Good for you! Way to show initiative and try to fix the problem rather than replace the board blindly like some of the people on here recommend.
完成的
添加一条评论
Hi
Reading your comments because I have an issue about the motherboard (at least is what I was told by the repair shop), any simple way that I can know where is the problem and how to solve it? Instead of looking for a new motherboard just as you wrote?
Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adithya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,201
