跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
Craked screen Glass or entire display broken?
Dropped the phone while running for a train smashed on the floor and well is basically useless since, Went into repair shops and without even looking at it they say it would be 320 euro to fix. The touch still works but the screen flashes when I turn it on and flashes white and black all over if you need pictures let me know.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello,
If there is effects on the display then the whole digitizer is probably at fault, so I'm afraid you would have to change it all
There is also a small probability that the fall damaged directly the motherboard, causing those problems, but it is far less common
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Conor 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 5
总计 76
