跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Apple Bricking devices repaired by third parties!?
So it seems that Apple is bricking devices repaired by third parties by stopping touch screen functionality. Seems that part manufactures have found a way around this but what if it happens every OS update? Also ambient light sensor not working after screen repair same for iPhone X. Does anyone have any insight on this issue and why its not being blown up?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Not sure if this helps you, but Apple rolled out an ``Bug Fix´´-Update to fix the Touch Issue with the iOS 11.3.1 Update. Still the problem with the Ambient Light Sensor persists since it's magically married to the screen and the phone it was equiped with. Once you change the Screen it decides to stop working. If you replace the screen while the phone is not turned off it might work but till you restart the device. Also once you start/restart the device with an aftermarket screen the key inside the Ambient Light Sensor (short ALS) gets void and needs to be re-programmed through an Apple Tool/Machine which they don't do since they only re-programm their own screens only. So your best bet is either to wait for Apple to roll out another update to fix this issue, or life with the fact that you now can't use the ALS anymore. You could also start suing Apple since this is against the Right to Repair law and has nothing to do with security or what so ever like they claimed with the Touch ID back in the days and still do up till these days. But hey if you ask me, if Apple continues doing things like these, I will start buying other manufacturers products since this is pure BS.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Techteam1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 102
