跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Doesn’t turn on
Hi so I have a iPhone 6S, that recently got into a boot loop, and now it doesn’t even turn on. I tried doing a hard reset, replacing the battery, and when I plug it into iTunes it tells me to restore, and after clicking ok, the restoration process begins but it always stops and gives me error 15. I appreciate any help. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
You sure it's error 15? I can't find any info on that (1015 however means your phone is jailbroken and permanently bricked)
完成的
添加一条评论
1个答案
I've worked on hours on iphones that have boot up issues and some can be cleared by connecting to iTunes and some can't. Its a software glitch that can't be repaired no mater if the battery is replaced screen or anthing else. At that time its time to replace the phone.
If you tried going into Recovery Mode the last resort is DFU Mode: I have attached an artctle that explains and also helps you to do that just click on the link.
https://www.ikream.com/2018/02/how-to-fi...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 50
