跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
activation impossible after reset
my problem with my iphone 5S persists for 2 months. After a simple restoration to the State Factory, I find myself facing a blocked iphone impossible to activate either manually or with iTunes (a message related to a SIM card that appears).
I tried the Apple Support Tips on their site, and even put it in DFU mode and activate it from iTunes, but in vain :(
I have consulted two repairers who tell me that there is a problem motherboard and the other assumes that it is a Software problem !
ANY SOLUTION PLS ??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Hi,
"a message related to a SIM card that appears" : Coud you be more specific with the error description ?
完成的
Hey;
( Disconnect iphone make sure that the sim card is well enclosed, and if you use a pin code of the sim; touch "unlock" to access and reconnect )
完成的
arnarque et messonge
完成的
Arnaque de Apple total réussite
完成的
添加一条评论
1个答案
已选择的解决方案
There is one simple thing you can try before concluding it’s a hardware issue:
If you put the SIM card in a different phone, check whether it’s recognized, and remove the pin code from it. Then insert it into the iPhone and try to activate. In some rare cases the sim won’t ask to unlock, which blocks the activation. Removing the sim pin circumvents this.
这个答案有帮助吗?
得分 1
1条评论:
My sim card is without a PIN code, and i've tried even with other sim card but in vain; this message is always posted on the screen : "
Your Iphone could not be activated because the activation server is temporarily unavailable. Try connecting your iphone to itunes to activate it or try again in two minutes. If the problem persists, contact Apple Support at apple.com/support"
完成的
添加一条评论
添加你的答案
noor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 26
总计 1,282
