跳转到主内容
微软制造的混合笔记本电脑/平板电脑。 发布于 2017 年 11 月。
38 个问题 查看全部
Individual key makes a "click" sound when pressed harder/faster
The A-key is affected on the surface book 2 keyboard, but only when pressing it harder than usual. It makes a "click" sound and as if it got stuck a couple of milliseconds. Not sure if this is a major problem as the button is still working and sounding not unusually when typing 'normally'.
Is it an issue with the rubber cup or key hinge/cap, or rather an issue with the key mount/ mounting clips, which are not easily replaceable with a key kit?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
I am having the same problem with my A and Q keys on my surface book 2. Any luck?
完成的
Same here with the keys a, q and r. It drives me nuts. I want to love the device but paying for a premium device and receiving a typing experience worse then typing on a 10 bugs keyboard is just not acceptable. I'll return the thing if there is not solution to it. Did any of you figure something out?
完成的
添加一条评论
1个答案
已选择的解决方案
Minor plastic spike in the key mechanism, not a problem in any way.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
H. H.C 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 748
