跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Lightning connector/loudspeaker fix gone wrong
So I went to replace the loudspeaker and lightning connector/headphone jack and everything was going really well and then it wouldn't turn back on. No screws were left out, put back in the wrong spot, everything was fine, but still no dice. I fixed a 5c that was run over twice and turned on after the first try yet I can't get this one to work. I thought it was the battery, so I replaced that also, but that wasn't it. Is there anything in the headphone jack/lightning connector that could cause it to not turn on? I'm really lost here, so any help would be appreciated, thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You could just be suffering from a defective replacement Lightning flex. Small parts such as these tend to have higher defect rates so it is entirely possible. You could try to put the old one back. I don't know what the specific problem was that forced you to replace it in the first place, but if the phone still booted up with the original, the put it back and see if the phone boots once again. If it does, then you likely have a bad replacement part.
这个答案有帮助吗?
得分 3
3条评论:
But would a defective lightning flex really cause the entire phone to just not turn on?
完成的
Sure it could, depending on what part of it is defective. That flex connects with the charging circuit so if the issue is there, it could pull the whole system down.
完成的
Great, I'll try throwing in another one and see what happens. Thanks for the suggestion!
完成的
添加一条评论
添加你的答案
Chase Crawford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 68
