跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
I spilled coffee in it about a month ago?
About a month ago, give or take some change, I was drinking coffee out of a red Solo cups, and for whatever reason, my apparently geniusness decided to put the cup on top of my Xbox. It spilled into the fan vent, I kinda panicked but since nothing really happened right away, I figured most of the liquid missed and hit the floor, well... More that what I thought got in there did just that. Long story short, I'm kinda stupid, took it apart, cleaned out the coffee with a rag (it had a lot of sugar, so I know that didn't help) and put it back together, which, in turn, made it worse. Now I'm lucky if I can even get it to load the initial Xbox screen. Sometimes I'll get all the way to my profile, then it'll shut itself off. Now I just use it as a charger box. Is there ANY way it might be salvageable, or is it the end for ol' sweet Chelsea? I also let it run WITH THE COFFEE IN IT, for about an hour, then it shut itself off. I still haven't put her back together completely, either. I still have hope, and I'd appreciate ANY help, even if it's just breaking bad news to me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
does it show any signs of corrosion, if so use isopropyl alcohol stronger the better like 90 % range and a toothbrush and clean the corroded areas. where abouts are you located
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
DonVhanDüde 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 960
