Xbox One Controller is Flashing Slowly and Won't Work.
So, last night, I turned off my console for the night and went to bed. This morning, I tried to turn the controller (and the console) back on to play. The console worked fine, and started right up. However, my controller started to blink slowly, and none of the buttons work. I've tried syncing it, changing the batteries, and unplugging the console, but it's still blinking. It only stops after I take a battery out, or leave it alone for a while. But if I press it's power button, it just blinks away (slowly, if that matters). Help?
29条评论
I’ve tried all solutions and still nothing works! I’ve tried hard resets, battery changes, usb connecting, etc., Nothing seems to work. Even tired these things on a different console! I hope there’s still something that can be done and all hope isn’t lost!
由 Patrick Vinson 完成的
Dude im in the same boat. I tried it all the home button new batteries the usb cord nothing works. Its saying not reading console
由 Oscar Macedo 完成的
Maybe the controller is broken.Try bringing to a shop which knows how to fix these stuff.Never go to big name shops because they might try to make you buy a new one.Maybe your warranty is still valid?If you are brave enough maybe you can open up your xbox controller.But I dont recommend this at all.
由 Zoken 完成的
im having the same problem with my two model 1708 (a standard issue One S controller) help?
由 Dog98k 完成的
Maybe try replacing it if your warranty isn't void.That is probably the best option if you cannot find out how to fix it.
由 Zoken 完成的
显示更多的24条评论
