跳转到主内容
Model A1224 / EMC 2316 / 2.26 GHz Core 2 Duo processor / Education only model. Released on March 4, 2010.
How to upgrade processor on 2009 education only iMac.
How do I upgrade my soldered on processor on my 2009 education only IMAC?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Sorry your only choice is to replace the complete logic board. Here's the needed logic board: iMac Alu 20" Logic Board, 2.0GHz (Edu) Apple P/N 661-5193 or if you live in the states: iMac Alu 20" Logic Board, 2.0GHz (Edu) Apple P/N 661-5193 As you can see its not too expensive less than $200 US.
Here's the IFIXIT guide you'll need to follow: iMac Intel 20" EMC 2266 Logic Board Replacement
Now do keep in mind this is a Core 2 Duo based system and Apple no longer supports it with the newer MacOS's El Capitan is the last OS this system will run. You may want to think long and hard before you spend any money on fixing this system if you think you'll want to get any newer apps. It might be wise to put the money towards a newer system (used or new).
这个答案有帮助吗?
得分 2
添加一条评论
Hi Dave,
If it’s soldered processor I am afraid that you can’t upgrade ( I seen few upgrades for soldered CPU / RAM but usually it not worth the money ).
Really good page for Mac’s is https://everymac.com/ultimate-mac-lookup... just put there your SN and you will see what you can/can’t upgrade etc...
这个答案有帮助吗?
得分 1
添加一条评论
The easiest is to start in safe mode.
这个答案有帮助吗?
得分 0
添加一条评论
Thank you so much for the video. I'll try to use it soon.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dave 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,303
