跳转到主内容
了解您在设备上维修可能所需的技能。
87 个问题 查看全部
What kind of adhesive should I use for display assembly?
DISCLAIMER: I haven't found any article about this so i make my own.
What kind of adhesive should you use to connect display assembly to phone's frame?
I believe that its some kind of silicon that is modified in a way that will melt under heat to make disassembly easier nor it doesn't seem like 100% silicon to me..
Thanks for any help! :)
- DK
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
iPhones prior to the iPhone 6S do not need adhesive. There are some pre-cut adhesive kits available on iFixit and other websites. You''ll also find similar kits for other models and Android phones.
If you don't want to buy pre-cut kits, you can get Tesa Tape and cut to length. This saves money but takes more time and when the adhesive also doubles as water resistant seal, you're better off with pre-cut.
The same applies to iPads. Don't use the tape that comes pre-installed on most digitizers, it's usually garbage. You can get pre-cut tape from BowlerTech; they use 3M tape but it works really well too.
iPhone 6s Display Assembly Adhesive图片
产品
Tesa 61395 Tape图片
产品
Tesa 61395 Tape
$5.99
这个答案有帮助吗?
得分 1
1条评论:
Can't you recommend me something universal for Aluminium to glass adhesive? I don't really wanna use tape nor assembly kit. Ideally i want to make my own silicon based assembly kit from specified compound.
Thanks for any help,
- DK
完成的
添加一条评论
Do you mean Iphone LCDs to frames. Are you refurbishing LCDs or do you mean Samsung LCDs to phone chassis. ?
Need a bit more information. Different adhesive for different processes.
这个答案有帮助吗?
得分 0
1条评论:
Isn't there something universal? its usually glass to aluminium which shoudn't make a difference in compound.. (i think)
Or can't you give me a source where i can find those adhesives? I coudn't find them on ifixit other then prebuilt assembly kits.
Like for now i need that for OnePlus 2. I used some from the internet, but it just makes things worse like it expands overtime and make display crack, etc..
thanks for any help,
- DK
完成的
添加一条评论
添加你的答案
David M. Košecký 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 8
总计 78
