跳转到主内容
The completely redesigned Optima, sharing the same platform as its sibling Hyundai i40, named the Kia K5 in the South Korean and China market, made its world debut at the 2010 New York Auto Show.
11 个问题 查看全部
Why has my reverse camera stopped showing a picture?
When I put the car in reverse, the dash display shows the electronic grid, but is no longer showing a picture of the back of the car and what is behind the car.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi Bill, I had the same problem, and after a month the grid also did not apear anymore, It is caused by moised in the camera , (and a fuse ) The solution is a new camera, however not the Original camera (this costs 250 dollar) you can order a camera at WISH €11,- and solder it on the connector wich came from your old camera.
I made pictures of the wirring so if you need futher instructions let me know
这个答案有帮助吗?
得分 0
1条评论:
Hello, i would like to apologise for my english in the first (not my birth language). I was searching for some answers about faulty backup camera. I woudl like to ask you, what camera did you buy from wish or another website? I have kia optima 2012 and there is plenty of them. Could you recommend any? Thanks, Petr.
完成的
添加一条评论
Usually, it’s moisture that got into the camera sensor. You can try pulling it off the car, taking it apart, drying it out with a hair dryer or similar device (heat gun, air dry, etc.).
I had this problem and wasn’t able to fix mine, so I purchased a replacement at rockauto.com
这个答案有帮助吗?
得分 0
1条评论:
where's this camera sensor located, please?
完成的
添加一条评论
添加你的答案
Bill Flanders 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 67
总计 3,086
