跳转到主内容
苹果的iPod Touch第六代于2015年7月发布。
149 个问题 查看全部
Wanting to bypass battery and use plug in cord only
Is there a modification that allows me to run the iPod (6th gen) continuously off of the ac adaptor and have the battery removed? Reason I'm asking is that I use this for our phone sys hold music so it requires it to remain plugged in all the time. Have the swollen battery/fire hazard issue that I'm trying to bypass.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I'm not sure about the iPad Touch but on the iPhone, once it is booted, you can disconnect the battery and let it run of of USB power. This does require that the iPod screen be opened and is not an elegant solution. Theoretically, if the charging circuit works well, it wont charge the battery (trickle charge) when it is full so even if it remains connected, it shouldn't degrade the battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Carmichael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 24
总计 1,481
