跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Water Damage - Display and Boot Issues
I recently got a Macbook Pro from my friend who spilled a cup of water onto the left side of the keyboard and he turned it off immediately and left it dry upside down for 4 days. It still didn't work so he let me see if there is anything I can do. First thing I noticed is that it turns on, and I know it's on even though screen is black is because the force touch on the trackpad turns on and I can click. The bottom of the computer does get warm but fan doesnt turn on at all. I know this still has a little life in it but I cant seem to get it to boot with the USB installer I made. Keep in mind he took out the SSD so I don't have an ssd to work with, only the USB Drive. I also opened the computer up and everything looks fine and no compression at all. Any suggestions would be greatly appreciated! Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
It sounds like you have some damaged components on the logic board.
While your friend did a gallant effort to prevent the water from damaging things. The fact the battery was still connected may have been the systems down fall. You see tap & spring water has minerals in it which are healthy for you and me, but can cause corrosion as well as allow current to flow across areas which shouldn't have the high voltages (shorting things out).
How about posting some good detailed images of the logic board (both sides) as well as any damaged areas you see. Adding images to an existing answer
While it might be possible to repair the logic board it may end up be easier to replace it if the rest of the system is in good shape.
Update (04/13/2018)
Sadly You'll need to get a new ribbon cable for the trackpad and a new logic board.
Here's the IFIXIT parts:
Here's the needed cable:
Replace a 2.7 GHz logic board (motherboard) compatible with the Early 2015 MacBook Pro 13" model laptop. Includes 8 GB or 16 GB RAM. Fix processing issues like unexpected shutdowns, reboots or water damage.图片
产品
MacBook Pro 13" Retina (Early 2015) 2.7 GHz Logic Board
$159.99
Replace a 2.9 GHz logic board (motherboard) compatible with the Early 2015 MacBook Pro 13" model laptop. Includes 8 GB or 16 GB of RAM. Fix processing issues like unexpected shutdowns, reboots or water damage.图片
产品
MacBook Pro 13" Retina (Early 2015) 2.9 GHz Logic Board
$191.99
Replace a 3.1 GHz Core i5 logic board (motherboard) compatible with the Early 2015 model MacBook Pro 13" Retina laptop. Includes 8 GB or 16 GB RAM. Fix processing issues like unexpected shutdowns, reboots or water damage. Includes ports: 2 Thunderbolt (Mini Display Port), 1 USB 3.0, and the audio port.图片
产品
MacBook Pro 13" Retina (Early 2015) 3.1 GHz Logic Board
$223.99
这个答案有帮助吗?
得分 2
32条评论:
Photos added!
完成的
Hows the other side look?
完成的
Sorry my bad! Uploaded!
完成的
@daviddpan - Lets get a another pic for the trackpad connector (middle top) it looks like you have corrosion on some of the pins.
In addition, I think you'll need to pull the heat sink as I see some staining on the chip so it needs cleaning and then fresh thermal paste.
完成的
The trackpad works fine though. Actually it's the only thing I can verify that works. The CPU does get hot after a while though. I'll send post a pic of the Trackpad connector very soon so just look out for the picture! Any idea why the display doesnt work? Display connector looks fine and no water was in contact with the display.
完成的
显示更多的27条评论
添加一条评论
The motherboard is on the inside left part of the Macbook Pro, so the water probably leaked into the keyboard and ruined the motherboard.
这个答案有帮助吗?
得分 1
添加一条评论
The fans don't spin on this MacBook Pro. With everything but the trackpad connector plugged in, do you get a chime on the internal speakers or does it boot to a question mark folder? If so, then you're likely ok and need to replace the trackpad cable.
这个答案有帮助吗?
得分 0
8条评论:
Well yesterday I connected to the tv and i know what I did but it made the boot chime and displayed flashing folder (I don't have ssd installed). Nothing on computer screen though. Cant replicate this again so I don't know how I did it.
完成的
That means likely you have an issue with the screen. Shine a light through the apple logo on the Retina display and see if you get a picture. If possible, try another screen as well to rule out bad screen.
完成的
Nope... From what I read, there is like a boot sequence on startup where it checks it's hardware. If something is bad, it won't boot up and make the chime. The trackpad works so...
完成的
It will boot and chime even if the screen is bad...lol
完成的
Yea...I got it to work few days ago but not anymore. Don't know how in the world I did it. Also, the fan turns on at boot right? Because my fan is prob broken cause it never spins.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
adsf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 768
