跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
Plantronics BackBeat PRO Right ear not working
I've aquired recently a used pair of Plantronics BackBeat PRO, and got the next issue - the right ear is not working at all, ar there any guides of disassembling the headphones and/or some advice related to reparing appeared issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Typically, when you pull the ear cup padding back, you will find 3 or 4 screws that hold the driver plate to the cup. Another setup is a series of slots and tabs. There, all you need to do is use a small flat tip screwdriver to disengage the tab and separate the plate from the cup
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Eugen-Andrew Coliban 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 4,780
