跳转到主内容
你了解并需要它们,鼠标让你的光标移动。鼠标维修指南。
481 个问题 查看全部
What is the best way to oil a mouse scroll wheel?
I have a mouse with a bit of a scroll wheel issue, as it will squeak every now and then, and is a little sluggish. What would be the best way to oil it? Would WD-40 work?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Had a Razer Deathadder squeaky mouse wheel. I used a little molybdenum graphite powder. Worked like a charm.
完成的
添加一条评论
4个答案
已选择的解决方案
WD-40 would not be a good idea. It is probably lint and fibers collecting on the wheel's axel. Most mice are easy to disassemble, there may be covers over the screws on the bottom of the mouse. Once the axel is clean then it should be able to move in its sockets without any need for oil.
这个答案有帮助吗?
得分 3
3条评论:
You think that could cause the squeaking as well?
完成的
I would say so.
完成的
I know this is pretty old but I'm dealing with this problem now and I've already cleaned the whole mouse. I disassembled it, took the motherboard out of it, and isolated the mousewheel to clean it better. I cleaned it using 99% pure alcohol and let it dry for hours. Now my mouse has 0 particles of dirt/whatever and 0 cat hairs in it.
However, the mouse wheel seems to be as hard as before, if not harder. Before cleaning it with alcohol, I noticed the wheel itself had a layer of some oily substance, so I think I DO need to re-lube it. What can I lube it with?
完成的
添加一条评论
Usually and very small "dab" of 3 in 1 oil with a Q-tip will do.
这个答案有帮助吗?
得分 1
1条评论:
When you say oil, what do you mean by that? (I know this question is old, but the issue persists)
完成的
添加一条评论
It’s a 3 in 1 silicone based lube at Home Depot it comes in a tiny bottle
这个答案有帮助吗?
得分 1
添加一条评论
The scroll wheel on my brand new HP X500 mouse squeaks consistently. Can't be dirty. I have food grade silicone, graphite powder, Fluid Film (recommended by Medeco), and 3-in-1 oil. Now to chose...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Reed Crosby 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 60
过去 30 天: 240
总计 30,575
