跳转到主内容
加入维修社区 - 创建账户
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Replace the Camera Protection Lens
Hi, I noticed there did seem to be a video on how to replace the Galaxy S5 Camera glass cover. My brother in law replaced one a while back but the camera never focused right, so since I got my iFixit tool kit I decided to try and free up whatever glass was stuck inside and replace the cover.
I tried almost everything from canned air to pushing a brush inside to bopping the phone to knock the glass loose that must have been inside, finally I took my fine angled tweezers and tried literally pushing the lens around by not touching the glass. I even got pretty firm using a bit of pressure. That did the trick, at least for now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
So... is there a question you need to have answered?
这个答案有帮助吗?
得分 0
2条评论:
Is there a procedure somewhere for this? And what tool should I have used to dig under the lens cover?
完成的
you will need a precision knife set to get the old lens cover off which can be found here: https://www.fixez.com/precision-knife-se...
you will need double sided adhesive to place the new lens cover on: https://www.fixez.com/categories/repair-...
you will need a new lens from here: https://www.fixez.com/store/samsung/sams...
how to video can be found here: https://www.youtube.com/watch?v=JeAW4Jut...
完成的
添加一条评论
添加你的答案
Mark Hayward 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 159
