跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
iPhone 8 not "showing"a charge after the replacement of LCD?
The LCD was replaced. Now the phone is actually charging but no showing the charge. Everything is working. It shows 1% but it actually is charged. Now, it does power on and off on its own? Left it unplugged for two days. It was charged when I came back to check on the process but still showing 1%. Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
was the battery disconnected during the repair and reconnected properly post repair?
这个答案有帮助吗?
得分 0
添加一条评论
Same here.. seems to be related to iPhone 8 & IOS 11.3..,
Michelle what iOS are you using? 11.3 perhaps?
这个答案有帮助吗?
得分 0
添加一条评论
If your battery is connected correctly as it should be then its related to IOS 11.3 software issues
这个答案有帮助吗?
得分 0
添加一条评论
Would not be the first problem iphone 8 has with replacement screens on ios 11.3, so could be the ios problem
这个答案有帮助吗?
得分 0
添加一条评论
Hello, i have this problem too... i change lcd for some OEM lcd and not work touch, now i make update 11.3.1 and touch work... but battery is still 0% and not showing the charging bold... when i connect to charger come first few seconds +/- 1100mA, after strarting OS come down on 200-380mA.... i inspect the board and like 2mm from battery connector missing one small part looks like capacitor etc.... i think this is the ptoblem.... can you tell me some good man what is the part? :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
7michele 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 13
总计 231
