跳转到主内容
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 个问题 查看全部
Ipad 4 repair question.
I want to repair an ipad 4 lte, but I want to make sure I get the right part. I've tried re-booting it and these grey lines still persist, and the touch screen still works, so I need a new lcd screen, right?
Thanks for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Is this the only thing you see on the LCD? Logically speaking it should be just the LCD that is defective. However, if the iPad has been dropped a lot, had a recent repair or came into contact with water, it might be a bad connection or logic board related.
这个答案有帮助吗?
得分 2
3条评论:
Yeah, it's only grey lines that show up, also I'm not sure if any of those things've happened to it.
完成的
Then the logical thing to try first is a new LCD.
完成的
Okay, thanks.
完成的
添加一条评论
添加你的答案
S Pin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 60
