跳转到主内容
加入维修社区 - 创建账户
这是一款于 2012 年 11 月推出的高性能台式计算机,搭载英特尔酷睿 i7 3770S 四核处理器、12GB 内存和 3TB 硬盘。它配备 23 英寸 1080p 触摸屏,并集成了 Beats Audio 音效系统。
HP Envy 27 - all in one - won't start
I actually have an HP Envy all in one 27 inch - p045 pc and it does not turn on.
Power cable works, and pc in back where it plugs in has a light. But nothing else.
I took the cover off, please notice the power switch and little board and cable that goes to PC/motherboard.
Is there a way to bypass or short switch to see if the pc will turn on, please take look. I want to make sure switch is working.
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
pcgeek these are real finicky about the power supply. They do require an original HP power supply and will not start without one. Did it ever work for you? Have you checked the power supply?
完成的
添加一条评论
2个答案
最有帮助的答案
I realized that opening the cover and just reseating the CMOS battery worked.
这个答案有帮助吗?
得分 1
添加一条评论
Same issue here. My PC froze and I pressed the power button for a few seconds to turn it off so that I can reboot it. But, it isn’t turning on now. The light next to the power cable is on in my case as well but it is white instead of green. When PC is running it would turn to orange. Couldn’t find a way to open the back cover so you did a really great job. I missed a critical project deadline because of this issue. My best bet is to take it to a repair shop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pcgeek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 4,471
