跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1234 个问题 查看全部
How do I swap malfunctioning logic board with locked functional board
Let me give you some details.
I have an iPhone 5c with a malfunctioning logic board due to water damage. It has a clean imei and is unlocked for any carrier. The phone boots up just fine but the charging U2 chip is all messed up and the display will go crazy every once in a while. I also have another iPhone 5c with a bad imei that is locked but the board is perfectly functioning. I do not have very much expirience in micro soldering. But I was wondering what components would I have to switch in order to maintain all data. I know the NAND Sphynx chip needs to be transferred over. But is that all? What chips need to be transferred over. I want to switch the data from the malfunctioning logic board to the working with locked / blacklisted board.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
i think the main chips you would need to transfer are cpu, nand and baseband. if you havent got much experience dont attempt it
这个答案有帮助吗?
得分 2
1条评论:
That's an understatement! Actually, even if you have a lot of experience, I wouldn't recommend you attempt it :>). It will be a lot easier to repair the charging and display issues than to transfer over the core components.
完成的
添加一条评论
添加你的答案
Adrian Ledesma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 81
