跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
553 个问题 查看全部
need help with stator do I need a voltage regulator or Diode
i got a riding mower with a Kohler CV15S i got a voltage regulator and hooked it up but when connecting the middle wire to the battery it sparked so i got to thinking maybe the stator shorted out so i got the flywheel off and i can see 2 copper wires are together and grounded with a screw its made that way so should i use a diode for this kind of stator? and take the voltage regulator back off ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Anytime that you have a battery system connecting to the stator like an alternator, you would need a diode, this prevents the reversing flow of the electrons to the other circuits to cause the damage like shorting out. I would also see if you can find a repair manual on your engine, there would be more technical information in it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tim Prichard 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 5
过去 30 天: 39
总计 1,368
